Bourgeois Neck Attachment Stability http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=51428 |
Author: | StevenWheeler [ Sun Jan 06, 2019 9:02 pm ] |
Post subject: | Re: Bourgeois Neck Attachment Stability |
Hi Terence, I'm curious as to why you don't make the neck block extension longer and glue that directly to the upper transverse brace. Steve |
Author: | Terence Kennedy [ Sun Jan 06, 2019 9:33 pm ] |
StevenWheeler wrote: Hi Terence, I'm curious as to why you don't make the neck block extension longer and glue that directly to the upper transverse brace. Steve It is difficult to get top positioned perfectly and still be in solid contact with the brace when gluing the top to the rims. The two are frequently not perfectly parallel. It is easier for me to leave a gap and wedge two pieces of wood in very tightly afterwards. Then I know there is good solid contact and maybe even a little back pressure. The beauty of using thin CA is that you can really wedge the pieces in tightly first. |
Author: | StevenWheeler [ Sun Jan 06, 2019 10:41 pm ] |
Terence Kennedy wrote: It is difficult to get top positioned perfectly and still be in solid contact with the brace when gluing the top to the rims. The two are frequently not perfectly parallel. Glad to hear it wasn't just me having that trouble. You don't have to off but a smidge to swing the center line a 1/4" at the tail. I've taken to treating the UTB as part of the rim set. Makes it easy to cut accurate notches in the linings and gives a nice solid joint at the neck extension. Since I close the box on the gobar deck, it's simple to add a few more sticks to complete the clamping of the top to that brace. I am in full agreement with you that this type of neck block should be tied in to the top bracing to fully stabilize the neck. Thanks for bringing it up. Steve |
Author: | meddlingfool [ Sun Jan 06, 2019 10:48 pm ] |
That's what I was doing for a while. I would leave the UTB square until the ends and butt it right against the sides. I would bend a second false side about 2" either side of the UTB, cut a precise notch in it and slide it over the brace, capturing the end. For my neck block extension, I would leave it long when making the frame, then clamp the frame to the tablesaw fence and bring the blade up, through the block where I wanted it to end, and would glue the UTB right to it. Ultimately I found there were no recognizable improvements for the considerable amount of extra work so I stopped doing it. |
Author: | Terence Kennedy [ Sun Jan 06, 2019 11:37 pm ] |
StevenWheeler wrote: Terence Kennedy wrote: It is difficult to get top positioned perfectly and still be in solid contact with the brace when gluing the top to the rims. The two are frequently not perfectly parallel. Glad to hear it wasn't just me having that trouble. You don't have to off but a smidge to swing the center line a 1/4" at the tail. I've taken to treating the UTB as part of the rim set. Makes it easy to cut accurate notches in the linings and gives a nice solid joint at the neck extension. Since I close the box on the gobar deck, it's simple to add a few more sticks to complete the clamping of the top to that brace. I am in full agreement with you that this type of neck block should be tied in to the top bracing to fully stabilize the neck. Thanks for bringing it up. Steve Did that approach help solve the late settling issue Steve? |
Author: | Michaeldc [ Mon Jan 07, 2019 9:18 am ] |
I’m currently installing the UTB as part of the rim assembly which has been working really well for me. I *am* installing my top first but I think it would also be possible to accurately install the top last. I use the mortise to help index the top during glue up (I can do this because my neck block is cut before assembleing the rims). Once the top is dry-fit I use a small block and a baby c-clamp clamped to the top it self to index the top side to side and front to back. All that’s left is to line up the tail block end. Right or wrong this is how I’m doing it. I will also likely look further into Trevor’s approach. The image is shown without the popsicle stick brace installed. I let it run through the fretboard extension pocket then trim with a router (1/4” bottom bearing) once the top is glued on. |
Author: | SteveSmith [ Mon Jan 07, 2019 9:29 am ] |
Michael, I like the way you've locked everything together in the UTB/neck block area. I did a bolt-on fret board extension but decided it just wasn't that hard to remove the glued on extension compared to the extra work involved. I do like to connect the neck block and UTB but it's a bit fussy to get it tight when you put the UTB on the top first. I will shamelessly steal your idea of putting the UTB in the rims with the neck block and try it on the OM I'm doing next. |
Author: | Michaeldc [ Mon Jan 07, 2019 9:43 am ] |
SteveSmith wrote: I like that Michael. Not sure I want to do that much work but I like the way it locks everything together in the UTB/neck block area. I know it looks like a lot of extra work but it’s actually really quick. The neck block fits every guitar I make. I only need to cut the extension to length and profile the block for the body radius and cutaway. I make a dozen at a time on the cnc so it’s a matter of reaching for one as needed. I’m down to about 28hrs to build a basic guitar not including finish and any fancy inlays. I use an acrylic template to make sure the geometry is correct before glueing up the UTB. |
Author: | SteveSmith [ Mon Jan 07, 2019 9:53 am ] |
Michaeldc wrote: SteveSmith wrote: I like that Michael. Not sure I want to do that much work but I like the way it locks everything together in the UTB/neck block area. I know it looks like a lot of extra work but it’s actually really quick. The neck block fits every guitar I make. I only need to cut the extension to length and profile the block for the body radius and cutaway. I make a dozen at a time on the cnc so it’s a matter of reaching for one as needed. I’m down to about 28hrs to build a basic guitar not including finish and any fancy inlays. I use an acrylic template to make sure the geometry is correct before glueing up the UTB. Standardizing the neck block and CNC'g them makes good sense. Every guitar I have made is different; I should probably settle on a neck joint design and move forward, it would no doubt save me a lot of time. |
Author: | Michaeldc [ Mon Jan 07, 2019 10:09 am ] |
SteveSmith wrote: Michaeldc wrote: SteveSmith wrote: I like that Michael. Not sure I want to do that much work but I like the way it locks everything together in the UTB/neck block area. I know it looks like a lot of extra work but it’s actually really quick. The neck block fits every guitar I make. I only need to cut the extension to length and profile the block for the body radius and cutaway. I make a dozen at a time on the cnc so it’s a matter of reaching for one as needed. I’m down to about 28hrs to build a basic guitar not including finish and any fancy inlays. I use an acrylic template to make sure the geometry is correct before glueing up the UTB. Standardizing the neck block and CNC'g them makes good sense. Every guitar I have made is different; I should probably settle on a neck joint design and move forward, it would no doubt save me a lot of time. I use exactly the same block for my “0” as my 27” baritone. Speeds things up a bunch no doubt! |
Author: | phavriluk [ Mon Jan 07, 2019 10:26 am ] |
What a dandy idea! So simple, so easy, so rational, and the brace stabilizes the rim and neck block a whole lot. I will guess that each of us knows somebody whose guitar's neck angle wandered around a fair bit during the top installation as a result of the rim edges moving in or out from the ideal and the movement causing the neck block angle to change. Thanks! |
Author: | Michaeldc [ Mon Jan 07, 2019 10:32 am ] |
phavriluk wrote: What a dandy idea! So simple, so easy, so rational, and the brace stabilizes the rim and neck block a whole lot. I will guess that each of us knows somebody whose guitar's neck angle wandered around a fair bit during the top installation as a result of the rim edges moving in or out from the ideal and the movement causing the neck block angle to change. Thanks! Yup... |
Author: | LarryH [ Mon Jan 07, 2019 11:03 am ] |
Yes, really nice set up Michael. Inspired for my next build. |
Author: | Michaeldc [ Mon Jan 07, 2019 12:04 pm ] |
Terence Kennedy wrote: StevenWheeler wrote: Terence Kennedy wrote: It is difficult to get top positioned perfectly and still be in solid contact with the brace when gluing the top to the rims. The two are frequently not perfectly parallel. Glad to hear it wasn't just me having that trouble. You don't have to off but a smidge to swing the center line a 1/4" at the tail. I've taken to treating the UTB as part of the rim set. Makes it easy to cut accurate notches in the linings and gives a nice solid joint at the neck extension. Since I close the box on the gobar deck, it's simple to add a few more sticks to complete the clamping of the top to that brace. I am in full agreement with you that this type of neck block should be tied in to the top bracing to fully stabilize the neck. Thanks for bringing it up. Steve Did that approach help solve the late settling issue Steve? I just popped down into the shop to measure a couple shop demo guitars, one being 6 years old, the other about 3 years old. Neither has budged at all from the original setup numbers. I personally think there’s great benefit to tying the neck block into the UTB. The way you come at it is up to you. Interesting discussion! Best, M |
Author: | Terence Kennedy [ Mon Jan 07, 2019 12:18 pm ] |
I agree, great discussion! For those of you that make the top brace/head block construct part of the rimset do you glue everything up and then radius sand the rimset? If you angle and flatten the upper bout for proper neck/upper bout alignment I assume you do that after the construct is all glued up as well? |
Author: | Michaeldc [ Mon Jan 07, 2019 12:38 pm ] |
Terence Kennedy wrote: I agree, great discussion! For those of you that make the top brace/head block construct part of the rimset do you glue everything up and then radius sand the rimset? If you angle and flatten the upper bout for proper neck/upper bout alignment I assume you do that after the construct is all glued up as well? The neck blocks are made completely square (except for the profile radius and the cutaway if present). That way I can clamp the block to the edge of the bench and glue on the pre-jointed rims which allows everything to stay complainer. Once the neck and tail block are glued in, I place them in the form and head to my radius dish and radius top rims and blocks. Then I glue in the linings, back to the dish sander. Then fit and glue in the UTB, back to the dish sander. Finally I install the popsicle stick brace and back to the sander. In the end you get your 1.5° +/- angle. How I do it anyway, M |
Author: | LarryH [ Mon Jan 07, 2019 2:59 pm ] |
In a strange way I instinctively tied the last couple of UTB's in to the neck block. Most likely a lot wrong with the details, and no measurements but it made sense intuitively to do so. I will now do the same but with lot more detail to process and intention. |
Michaeldc wrote: Terence Kennedy wrote: I agree, great discussion! For those of you that make the top brace/head block construct part of the rimset do you glue everything up and then radius sand the rimset? If you angle and flatten the upper bout for proper neck/upper bout alignment I assume you do that after the construct is all glued up as well? The neck blocks are made completely square (except for the profile radius and the cutaway if present). That way I can clamp the block to the edge of the bench and glue on the pre-jointed rims which allows everything to stay complainer. Once the neck and tail block are glued in, I place them in the form and head to my radius dish and radius top rims and blocks. Then I glue in the linings, back to the dish sander. Then fit and glue in the UTB, back to the dish sander. Finally I install the popsicle stick brace and back to the sander. In the end you get your 1.5° +/- angle. How I do it anyway, M Really appreciate your insights Michael. Thank you for sharing them... |
Author: | StevenWheeler [ Mon Jan 07, 2019 10:01 pm ] |
Terence Kennedy wrote: Did that approach help solve the late settling issue Steve? Yes it did, I haven't had to re-address a setup since. I think it's interesting that a number of us came up with similar solutions independent of any prior discussion on the subject. Like LarryH said, it just made sense. |
